I purchased this fork a while back but still haven't got the setup right. I'm 220lbs, about 240 with gear and the bike is a fairly heavy one.
It's a Revelation dual air fork. I've experimented with the extremes of positive and negative chamber pressure but can't get it where I want it. Right now I'm running much less pressure than is recommended for my weight yet still only using half the travel. That's the first problem.
Second is I get little to no sag when I sit on it. I thought I'm supposed to see 1/4 of the total fork travel in sag. I get maybe 3/8" with ultra low air pressures.
It also has a lot of brake dive. I assume this is due to the frame's angle.... This bike came with a cheap but too stiff coil spring fork. To me it looks like it has too much rake but it's about the same as my friend's Specialized Epic with a cheaper fork and better ride.
I've even tried it with no negative pressure. Is there some magic balance beteen the positive and negative chamber that I'm not getting? I've searched and been on mtbr.com for a month now trying different things.
One other thing, if I set the air pressure really low to where it uses some appreciable travel, it's too soft when I go to pedal hard. I have the option to lock it out of course but that's not always possible in some areas.
