I bit the bullet, and went ahead with TC-W3. Its viscosity is thicker than that of MMO - I remember somebody was saying MMO is similar to a 5W. I suppose that would make TC-W3 a 10W or thereabouts.
Anyhow, the ratio for my truck is 145 ml to a 92 litre tankful (4.9 oz to 24.3 gallons). I used a measuring cup to pour the exact mount into a container, and diluted the mixture a bit with gasoline because it was a bit on the thick side. It's been there for 200 km (125 miles) so far.
So far, there are two differences I've noticed when compared to MMO. The first is the engine idles quieter and the second is an interesting observation. If I let my truck idle with the AC on, the second the compressor disengages, the engine vibrates/shivers for 2 seconds before idles normally. Nobody was able to tell me the cause or remedy. But on the first tank of TC-W3 in there, the vibration has lessened to the extent where you can only feel it if you're paying attention. I wonder if it will disappear on the second or third tank with the recommended dose of TC-W3.
