Originally Posted By: HondaMan
I would do the following while under warranty:
1.) Use an approved oil
2.) Run HALF the suggest drain interval
This is not a blanket statement, this is a VW PD statement.
After warranty, have at it .... read the board over and over, you'll never be able to find an agreed upon answer other than that most feel the interval suggested is too long.
THat's interesting because everything I read on TDIclub says 10k interval is fine. What is shocking is shorter intervals, actually produces higher wear numbers.
Why? I dunno, but 505.01 oils have a tendency to shear down, then thicken back up as soot increases in the oil--- maybe since by keeping oil that is sheared down to a lower viscosity is causing the higher wear numbers.
