antilog is the inverse of log (reversing the log process). On most calculators you can just hit the "Inverse" key, then the "Log" key. You can do the logs in any base, 10, e, or whatever, so long as it's the same base throughout the equation.
You basically are transforming everything to logs, then averaging, then untransforming.
