2001 ZRX1200, 4 cylinder, liquid cooled, engine mods include JE 12.5:1 high comp pistons, ZZR1200 cams and ZX11/ZZR1200 40mm carbs. Over 87,000 miles on the bike total, 30,000+ miles with the listed pistons and cams. Bottom end, transmission and clutch are original.
Report looks pretty good with respect to consistent stable trends with the bike overall. Aluminum has been suggested on this forum as being from the clutch, don't see any reason to believe it's coming from anywhere else at this point after this many 5,000 mile oil changes.
Oil change was right after a 260 mile ride on a hot day, that helps out with a flashpoint of 455°. However, Amsoil lists 442° as flashpoint... Another Blackstone anomaly. Comparatively, the others are lower on flashpoint, which would indicate the various oils could have retained viscosity a bit better all else equal on the previous oil changes.
Pleased with how the Amsoil 20w50 V-Twin performed given it started at a cSt of 18.5 and ended at 17.02.with wear numbers better than established norms for this engine over the past 30,000+ miles for everything other than Al, however it is the best Al number in the past 21,000+ miles. Al made its first jump in 2018 at 60,872 miles.
