Aluminum is holding steady. As had been shared in previous discussion in other analysis threads I've posted, folks say it's coming from the clutch, and I haven't done anything to the the clutch to this point. Silicon is up, not concerning to me (Dual foam uni-pod filters, cleaned and re-oiled after the sample was taken) however not what I expected with a SUS vis of 80.5 and cSt of 15.65 from this oil, or maybe it did well given what I share below.
The oil had a 2,300 mile round trip to Texas in the early summer of '22 in heat that would make the devil run for cooler climates. Then another 1,500 miles the rest of the summer of '22 in Colorado. Spent fall of '22 thru Dec of '23 in North Carolina, only rode 350 miles in that time. Bike/oil had about 1,000 more miles since the move back to Colorado in Dec of '23 until the sample was taken in early May of this year.
My thoughts on the "low" viscosity" are:
-The 105+ temps and high speeds ridden in Texas in '22, sheared down the oil as the bike ran without complaint on that trip despite the heat.
-The radiator got a good size leak in Amarillo on the return trip. I spent the rest of that day limping it home (350 miles to Colorado) after a good shot of stop leak and watching the temp gauge cycle up/down as I could not keep the radiator full otherwise it would puke out the "sealed" leak the stop leak helped to fill.
-Flashpoint is 400 deg F, down a bit from the previous samples, and this sample was taken after a 30 mile ride where the ambient temps were 50-60 deg f.
-The oil was not "burn me hot" as I have come to expect with past samples being taken while the oil is draining.
Anyway, this OCI saw all manner of different things. Could possibly not be representative, and another run with this oil would be a more fair assessment.
Read the report as RL 20/50 far left with arrow, (3) Mobil 1 10w40 4T marked with arrows and (1) M1 20/50 VTwin with an arrow in between two of the 10/40 4T's.
I only took a sample, this oil is still in the bike. I have all 3 oils on hand. Which one would you all choose for the next OCI?
Cheers.
Cheers.
