http://www.tribologia.org/ptt/tribv35.htm
Quote:
6-2004 Tibologia
Witold Piekoszewski, Waldemar Tuszyński
Instytut Technologii Eksploatacji - PIB, Zakład Tribologii, Radom, Poland.
Scuffing and Rolling Contact Fatigue as Effects of the Chemistry of Lubricating Oils
Zacieranie i powierzchniowe zużycie zmęczeniowe jako efekty kompozycji chemicznej olejów smarowych
Key-words: Four-ball tester, scuffing, rolling contact fatigue, AW additives, EP addi-tives, SEM, EDS, GDOES, FTIRM
Summary
The aim of the research was to establish a relationship between the re-sistance of a tribosystem to scuffing and surface fatigue as a result of the type and concentration of AW/EP additives in lubricating oils.
Lubricating oils of various chemical composition were tested. A base mineral oil was blended with commercial packages of lubricating addi-tives of AW and EP type, at different concentrations. The AW additives contained ZDDP, and EP ones - organic S-P compounds.
The tests were performed in two different four-ball testers. The first one (denoted as T-02) was used to determine extreme-pressure (EP) properties at sliding friction - a new method for testing scuffing and sei-zure was employed. The second instrument (denoted as T-03) was used to assess the surface fatigue (pitting) life at rolling movement.
It is shown that AW additives not only improve EP properties but - at a small concentration - are also beneficial for the fatigue life. An in-crease of the content of AW additives leads to an improvement of EP properties but may reduce the fatigue life.
EP additives - even at a small concentration - significantly improve EP properties. A small concentration of EP additives gives no influence on the fatigue life. An increase of the content of EP additives leads to a further improvement of EP properties. However, this is accompanied by a much decrease in the fatigue life.
By using a scanning electron microscope (SEM), energy dispersive spectrometer (EDS), glow discharge optical emission spectrometer (GDOES), and Fourier transform infrared microspectrophotometer (FTIRM) for analysis of the worn surface, the authors identified mecha-nisms of action of various lubricating additives under different friction conditions. It must be emphasized here that GDOES is mainly used to analyze flat surfaces; results for small wear scars on non-flat surfaces (balls), like in this study, are published very rarely.
