Youtube mixing video makes me cringe
Originally Posted By: 01_celica_gt
LOL this guy says in his youtube video comments section, that it took him 3 years to come up with the right blend because he is a perfectionist, perfect has a new meaning now...
My thoughts on his video ...
1) clearly makes the disclaimer up front, but he also is advocating it's use for others, or he'd keep it to himself and not post on 'Tube. When one posts on the 'Tube, then they invite all the critiscism they may well deserve. If this were only for private consumption, he'd keep it quiet. He does not, so we don't have to keep our comments to ourselves, either.
2) he mentions that his car (a 4.6L 'Vic seen in the background) has 252k miles. So what? That's nothing to those engines. Routine maintenance will get any 4.6L to 400k+ if you take care of it with a decent scheduled program.
3) I'll mention that my 1995 Village had almost 250k miles when we sold it; we see it around town every once in a while and it has almost 260k miles on it now. The vast majority of it's life sufficed with good ol' conventional oil of 5w30 grade from both brand names and house brands. Never a drop of special stuff needed; no ATF or Stop Leak. Never a witches brew of vis. Just routine oil changes. It runs as good today as when it was new. And after experiementing with greatly extended OCIs, it still ran fine and was clean inside.
His 14w-42 is apparently the lubricant version of Goldie-Locks porridge; because 15w-50 is too thick and 5w30 is too thin ...
Heaven forbid he just grab a 15w40 HDEO and be done with it. And what's with all the additives? Is he concerned that there just aren't enough in the blue bottles?
This guy is the epitome of anecdotal experimentation and confuses correlation with causation. He takes one of the most robust chassis/engine combinations known (Panther with 4.6L) and credits his brew for it's longevity, when hundreds of thousands of those cars exist well past his mileage using bargin brand lubes and filters.
If anything, this is simply an extension of my data in the normalcy article showing the 4.6L engine really does not care what you put in it.
Maybe I missed it, but I didn't hear him mention his OCI. Probably changes it every 2,500 miles because, as good as his home-brew is, nothing is "better" than new oil.
Hmm ... if there were only an oil that had a viscosity close to 14w42 right out of the jug. It's too mad no one makes something close to 14w42 ... would be perfect for this!
Yeah...because all Ford Modulars love a 20W-50 aka 14W-42 Syn-Blend with a No-Leak and STP "additive package".
Dave - you will cringe even more, here from the comments of the video is his OCI:
Originally Posted By: themanshere74
Took about 3 years of adjusting to get it how I wanted it. I am a perfectionist and now my motor runs nice and smooth, no leaks and quite too. And after a 3k oil change, the old oil is almost the exact same consistency (no thinning and no thickening). I put it in the freezer below 0 F, new and used it flowed good.
Originally Posted By: Whitewolf
Originally Posted By: montero1
Croc clogs....
Pouring a thimbles worth of Stop leak back in the bottle.
They still make STP?
Pouring the additives in, in a circular motion.......
I'm actually sad now.
Don't you know anything? It's very important not only that the additives are introduced in a circular motion, but also that the direction of rotation is correct if one is to achieve optimum performance.
For optimal blend, and for it to mix in the best, this is true.
I air shake my funnels 50 times before putting them back in my vehicles. To get any residual drops of fluid out. This keeps it from draining onto carpeting in trunk, backseat, etc. I also put it in a bag. Usually a Walmart bag..
Thinner is better! Thicker is usually unnecessary.
Hasn't BITOG taught you anything?
*seriously though... BITOG is more credible than the individual in the video.
Originally Posted By: gfh77665
You all can bash him if you want, but he made it clear in the first 20 seconds that this was "his mix" and he "was not recommending it for you", and "you should decide for yourself what you use". He called it "his disclaimer".
Why can't it simply be accepted as he verbalized it, as just his opinion for his vehicle?
because this is BITOG and its our duty to correct misinformation! at least I think so.
3:33 than ???
3.3 Repeating.
Wow there's almost 7 minutes of my life I'll never get back.
Correct! Most of that 7 min. was taken up watching him pour oil in a 5 gal. bucket.
How unorthodox. Doing all that chemistry out in the open where dust and pollen could get into the oil. He should've sprayed down the driveway and yard with water. Imagine what the inside of his engine must look like by now! The horror! /endsarcasm
Gotta admit that first pour of 20w-50 had a nice beat to it. Almost sounded like a remix (bad pun, LOL) at first.
I've always blasted my funnels with carb cleaner and wiped them down with a lint free towel.
yep...
You mean where he adds 3oz of Mobil ATF to the mix?
I had a good laugh, i thought about a poster at first with TGMO and Mobil 1. I can see the same thing going on there, here we have a 0w14.5 with a VI of 235. lol
...but he forgot the Marvel Mystery Oil.
I've calculated that he will need 2.5 ounces and it must be poured into the bucket in a counter-clockwise circle before any synthetic oil is added.
Once the mixture is completed it should be energized with a flux-capacitor set to 1.5 gigawatts before being poured into the engine.
Few professionals actually use a Home Depot bucket. Rather, the plain wrap white ones for a third of the price deliver twice the cred.
Using the anti-glug feature whilst pouring helps, too.
That STP looks kinda thick!
