So, as stated in my other threads, I have this 99 Honda Passport, or rather my Ex has it, with 195 on it so I plan on servicing the differential. What I'm wondering is if I should just do a drain and refill (apparently there's no drain plug. You have to suck it out with a tube through the fill hole) or should I go to the much bigger bother, and for me expanse, of dropping the cover and doing it that way.
Now, under the heading of a little knowledge is a dangerous thing, I'm of two minds on this....
First is the most simple and expedient way to do it is through the fill hole, especially since it doesn't look like there's any leakage from the housing.
On the other side of the coin, in a number of the YouTube videos I have just watched regarding differential servicing, when guys did the cover removal version, obviously fluid would drain out, but inside the cover and on the gears themselves was left a BUNCH of gunk.
In some cases they wiped out millimeters thick gunk from inside the cover, with all kinds of crap stuck to the magnets, and then sprayed down the gears with whatever solvent to get the rest of it out before putting it back together and refilling.
So I'm wondering if I just suck out the old fluid and put in the new will that loosen any gunk to the point that it would somehow break free and intermixed with the new oil and somehow get in there and mess up the gears.
I don't fully understand the dynamics there so that's the best way I can express it. But I think y'all get my point.
Or is that not really likely to happen with a simple drain (suck out) and refill despite the differential's age?
I would like to avoid removing the cover, if that's practical, because in order to do that I'm going to have to take it to somebody and I would like to not spend the money, but only if the other way is reasonable.
