- Joined
- Jun 13, 2013
- Messages
- 3,075
I’d say I’m willing to spend $250 max if it’s a really good one and will last a long time. Just need to do some research to determine if I need to spend that much.What's the budget? How concerned are you about security? This is a very broad field if we scope in SMB gear or if you are concerned about security (though running a 15 year old router, I get the impression there's not a lot of emphasis on that).
Not sure if I need that, because we have a fairly small, 1-level 1450 sq ft home. It's probably only 50 feet long.Its 2023. Single WIFI accespoint is not optimal, wifi range has not increased that much.
I would look at Asus Mesh with minimum 1 extra node. But really any wifi 6(AX) mesh will be good enough.
Something like this. Have two of the old wifi 5 version myself. Perfect for desktops without wifi aswell.
https://www.amazon.com/ASUS-XD5-Dua...id=1687119008&sprefix=asus+mes,aps,203&sr=8-8
Question about the mesh wifi systems, just in case I decided to go that way, either now or in the future:That depends on how many walls you have I would say. Definitely get a router with mesh capabilities for the future.
No outdoor space at all?
Do all the mesh units require being connected to a modem, or does just one router connect to the internet source, and then transmit its signal to the other mesh units, which amplify and extend the signal?
Not sure I follow.Can do both. Ideally you want a cable between the 1st router and (one)node. But that is not necessary, my desktop is connected to the node that uses wifi to talk with the router.
Not sure I follow.
Let's say, for example, I buy a TP Link Archer AXE75 router, which is, incidentally, mesh-capable. I place it next to the cable modem (which is on the west end of the house (it's on the far west wall, actually).
Then, later on down the road, I decide I'm not getting a good enough wifi signal on the far east end of our property, which is approximately 235 feet from the router (according to Google Maps), and also has to penetrate the bulk of the house to get there.
I can just buy a compatible mesh device and put it in our bedroom (which is on the east wall of the house) and not have it connected to a modem? It can just take the signal from the "mother ship" router and amplify it?
Basically, yes, but you will face around a 1/2 speed penalty if you are using the second wifi device as a wireless repeater. It's best to have a wired "backhaul" connection between the devices for a true "mesh" topography.Not sure I follow.
Not half there are multiple channels antennas and frequency's. Mimo 4x2/4x4 etc.Basically, yes, but you will face around a 1/2 speed penalty if you are using the second wifi device as a wireless repeater. It's best to have a wired "backhaul" connection between the devices for a true "mesh" topography.
OK...so I'd need to have the 2nd mesh device connected to a modem, OR, have a cable connecting it to the main router which is, itself, connected to the modem?Basically, yes, but you will face around a 1/2 speed penalty if you are using the second wifi device as a wireless repeater. It's best to have a wired "backhaul" connection between the devices for a true "mesh" topography.
Thanks. I should have qualified my statement by saying "up to 1/2 speed penalty" depending on network loads, the number of simultaneously connected divices and your ISP provided speeds. Either way, to someone who is comfortably living with 54G WIFI it isn't going to be noticeable one bit!Not half there are multiple channels antennas and frequency's. Mimo 4x2 etc.
500mbit without backhaulon wifi 5
