Originally Posted By: BuickGN
Originally Posted By: vxcalais
Originally Posted By: Drivebelt
That chart that recommends not using 5W-30 in below 59F weather is outdated, and really only applies to the old Group I based 5W-30's that were in use in the 1980 - 1990's.
What happened to 'Follow what the manufacturer recommends' ? Does it only suit when they recommend a 5w30 and someone uses slightly thicker ? When they recommend thicker is it out of date ? 20w50 oil is not poison......
Agreed.
Always follow the manual. The manufacturer knows what's best.......... unless it recommends a heavy oil then disregard the manual lol.
Obviously my post should have read "not using 5W-30
above 59F" ..oops.
If you just want to blindly follow the chart then that's fine. But then that is just not doing any analysis or thinking about the recommendations on the chart.
Notice that 10W-30 is recommended in all-weather conditions, even above 100F -- the same range as the heavier viscosity oils. So a 30 weight oil is OK above 59F if it is a 10W-30, but a 30 weight is not recommended if it is a 5W-30? Now why would that be -- they're both 30 weight oils. What could possibly be wrong with a 5W-30 compared to a 10W-30?
How about that the old 5W-30's when using lower VI Group I base oils, loaded up with VII's, just didn't hold up that well in hot weather. It was the same problem with the GI based 10W-40's back then too. They were poor oils because they had to be loaded up with VII's to make the viscosity spread. Factor in that GI base oils back then weren't very good base oils to begin with, and you have concerns about a 5W-30 or 10W-40 GI based oil holding up in hot conditions.
As I already pointed out, with the Group II+ base oils being used in 5W-20, 5W-30's these days, this is not an issue any more. Look at Ford and their 5W-20 recommendations for the F-150. Even if towing a 7,000lb trailer in 115F weather, Ford says the current 5W-20's are good enough to handle it.
The current GII based SM/GF-4 oils are in a whole different league performance wise compared to the previous GI oils they replaced, so using a 5W-30 in place of a 10W-30 these days it not and issue anymore.
