Coworkers car; lab is B-S; no MU oil.
Al 3
Cr 0
Fe 4
Cu 3
Pb 5
Sn/Moly/Ni/Mn/Au/Ti 0
K 1
Boron 71
Si 5
Na 96
Ca 1741
Mg 7
Ph 614
Zn 770
Barium 0
SUS@210F 53.1
cSt @ 100C 8.2
FP 375
Fuel Gly ?
Water 0
TBN 2.4
Insol .3%
B-S flagged sodium and lead. They did not know the oil type and indicated some use sodium as an additive. Indicated to check back after another 5K run.
Coworker indicated he drained oil into a butter tub which was clean and then to a sampling bottle. There is another UOA I will be posting on his other car, a subaru, which also has high sodium, so there will be no action taken until a direct sample is taken.
Al 3
Cr 0
Fe 4
Cu 3
Pb 5
K 1
Boron 71
Si 5
Na 96
Ca 1741
Mg 7
Ph 614
Zn 770
Barium 0
SUS@210F 53.1
cSt @ 100C 8.2
FP 375
Fuel Gly ?
Water 0
TBN 2.4
Insol .3%
