xB-Mobil 1- second tank
Oregon
Numbers for the second tank are good. This was a bit of a surprise because last Sat a quarter of a tank was burned in the Coast range on Wolf Creek Rd between Eugene and Florence. There was miles of one lane windy road that required second and third gear.
33.33
32.45
32.95
32.42
31.42
30.975
30.59
31.22
32.1
32.719
30.08
31.826
32.297
32.67
33.33
30.31
34.789
31.7
37.035 < Mobil 1 5w30
37.6757
Btw, the other two cars at my house are running 5w30 too. '06 Scion tC PP. '92 Honda Civic GC gold. The Honda seems to like the GC at high rpm. But seems a little sluggish at slow speeds. Kinda thick?
Originally posted by ChromiumSteel:
The PP was $3.97 a qt @ Wal-Mart. But I think I'll spend more for Mobil 1 next time for the tC.
**** i must be spending too much for AMSOIL Series 3000 then.
That's because the bypass valve is opening. That is not a good thing. Use the recommended viscosity.
The Castrol Syntec 0w30 is almost a 40 weight at 12.1 cSt at 100C. The typical 5w30 is 10.5 cSt at 100C. Many including myself realize sluggishness when using GC in an engine designed for the thinner oil. Oil volume pumped through the engine suffers, as does power and economy.
Try a thinner synthetic next time and compare the hot/cold and highRPM/lowRPM power. The Castrol Syntec 5w30 is about the thinnest 5w30 available, and gives very low wear numbers.
