I have a 2007 Mazda 6 2.3L Atx. I have had the spin on filter conversion done and back when I first got it I used what I found to be a filter equivalent: the Amsoil EAO33.
I found that by double-cross referencing the Mazda filter that came with the kit, to wix, then to Amsoil.
Recently I looked it up a different way and Amsoil now says an EAO57 is the correct filter (I use the same filter as a 2.0L Mazda 3 and looked it up using this route).
Thoughts? Should I change the filter asap? I'm due for my 60K service at about the end of the month and plan on using the 57, are there larger capacity options and how can I find these?
