JHZR2
Staff member
This is an offshoot of my diesel misfire thread found here:
https://bobistheoilguy.com/forums/threads/mercedes-diesel-misfire-after-hg-replacement.384310/
However it is more general interest, so I figure a separate thread may be useful to others.
I had a broken camshaft, as can be seen in the linked thread. I think it was tightened down wrong.
Here’s the bearing that was over the break (some call it the cam tower):
There is a little line that can be seen, in the middle, in the direction of rotation. But there’s also a perpendicular scratch, seen in the bottom most photo, and some “speckles” from foreign debris, probably there when the crack first happened (and subsequently flowed out, no debris present.
I can’t seem to feel any of it with a fingernail.
Is this bearing useable?
Is it useable with a new cam?
Is it useable with a good used cam?
Will a good used cam wear in its surfaces and asperities with the surfaces and asperities of this bearing?
There is plenty of thickness left on the bearing from what I can see.
Thanks!
Thanks!
