WJB bearings?
Central NY
Anyone ever use these? I ordered one as an emergency replacement on the Cherokee (first time I ever had one catastrophically let go ...). Looks to be IDENTICAL to a timken wheel bearing.
Has the red seal on the inside - which I have only seen on Timken, plus it seems to be quite a bit heavier than the others I have seen before for these Jeeps. Definitely heavier than the ones that are in the Jeep now.
LOL! when it comes to bearings: looks can be deceiving.
You can ask our resident bearing engineer and he will tell you all the horror stories about bearings.
Q.
I tend toward SKF for bearings these days, even though some of them are allegedly made in China as well. It really hurts that the name Timken doesn't mean a danged thing anymore.
Timken are repackaged bearings nowadays, citing that
(a) recently bought some for 7th gen civics, they are chinese bearings.
(b) bought some for 5.5gen Camry: both sides are repackaged (US made) NSK bearings.
When it comes to bearing quality, it's the luck of the draw: you can get some seriously good bearings but due to some human errors/operational anomalies, they would fail prematurely.
Alternatively: you can get some chinese made bearings that lasted over 100k easily and still good...
Go and bet on it, and see how it goes?
(*I'm not at all worried in my case,for I have press to press bearings if they fail prematurely, at the cost of the customers of course*)
Q.
My BIL's MPV SKF packaged bearings where Korean stuff...
Q.
The last Timken I got for the Cherokee were made in China - identical to these. Along with the ones I changed last week.
It's a unit bearing so I can have it changed out in 30? minutes.
My Grand Cherokee has an SKF hub and a Duralast hub from autozone. The duralast is the better product. Hate to say it. It looks like a rebranded Timken.
For roller bearings in my rear axle, one side is a Napa roller bearing made by SKF; garbage. The other is a Timken and it's pretty good. Time will tell.
