Originally Posted By: CharlieBauer
Originally Posted By: ZeeOSix
Frankly, ISO55000 was a troll trying to discount the validity of ISO 4548-12 ... he failed.
Reading the threads with you and ISO55000 certainly revealed that he had a very deep dislike for you, but he knew what he was talking about.
Having read ISO 4548-12, I can see why he was saying what he did. An early example in one of the threads is where he refuted the idea being put forward via the batcave that there was unintended bypassing going on. The standard specifically calls for that to be checked before running the test.
He tried to make people think he know what he was talking about, and was trying to say ISO 4548-12 wasn't worth anything. You notice he's not here anymore unless he's in hiding and keeping mellow. I don't know why he was so [censored] off, I mean if the batcave findings were accurate then the media is better than what's claimed, and there would have been a reason why the test was coming in low. And yes, Section 9.1.1 does say to test for leakage around the filter element, but it doesn't say exactly how, which leaves it open to being done either right or wrong. A test procedure is only as good as the people interpreting and running it. That's why they need to be written very clearly to curb the chances of misinterpretation.
As to his wanting to compare 4548-12 to 16889, I haven't read 16889 but have found that the test dust is identical and that the bench testing equipment sold for the testing can test for both standards. Hydraulic oil is also used in both tests. So it looks like he knew what he was talking about when he said he was going to compare the two. Yes 16889 is for very high efficiency purposes and 4548-12 is for less efficient filters, but they use the same testing equipment, the same dust and aim to report on the same performance metrics.
Except the results of the 'same performance metrics' are in a different league. ISO 4548-12 is not meant for testing oil filters above beta 75, but they do say you can extrapolate beyond beta 75 but only for higher efficiency filters. ISO 16889 is specifically meant to test oil filters above beta 75 (the summary statements of each ISO test lay that out as posted before). ISO 16889 stipulates/recommends that the following beta ratios be measured and reported (snit it below). Notice they go all the way upto beta 1000 ... so for goodtimes I'd have to say those particle counters can do better than some think.
I've been in the testing world forever, and when I use an industry test standard (ISO, MIL-SPEC, etc) it has to be followed correctly or QA dudes looking over the test conductor's back will not buy off the test. That's how it should work. If it works that way in the oil filter industry, well who knows for sure. If it happens like that at someplace like the SwRI, well they could tell you and I'd think they have their own in-house QA system in order to give confidence to their test results.
I also don't think he was trying to discredit the test. Simply that to interpret results, you need to better understand the test, as well as ask how realistic is the test compared to real world conditions. That is explored more here:
https://www.cumminsfiltration.com/sites/default/files/MB10046.pdf
IMO, he was trying his hardest to discredit ISO 4548-12 in some way to defend the WIX XP's low efficiency test numbers. Looking back at those threads, it seems he was arguing against himself because if the low numbers was due to an internal leak then the media is actually better than it's claimed to be.
Nobody, including myself, has argued that ISO 4548-12 is a test to try and realistically compare real world conditions. I have however, and always will say that it's the only real current test standard that is used to compare oil filter efficiency in a decent manner - that's the whole purpose of a test standard. If you have read the stuff I've posted about the SAE Bus Study and showed the graph from the report, it can be seen that the filters that tested the most efficient in the lab bench test also showed to give the cleanest particle count data in the oil. I'd say that's a pretty good indication that if Filter A tests more efficient than Filter B using ISO 4548-12 that Filter A is also going to keep the engine oil cleaner in real world use. Pretty hard to refute a correlation like that.
