This filter has only been run for 300 miles! I am doing a Yamalube Ring Free Plus Shock Treatment! third oil change on 1000 miles, I did cut open the first two oil filters.
Wjen I want real quality I grab a OG ultra or titaniumShame on that WIX. That is dangerous.
I do not think so, I had changed the oil previously two different times at 300mile intervals. Cut the filters open the other filters did not do this. I am going to dig it out of the trash and check the date on the can.oh Mann not anotherHummel filter
It's not an oil treatment so i doubt it's able to do that to the filter because there shouldn't be anywhere near enough in the oil through dilution. Did the oil reek of gas?
Here is the other oil change with 300 Miles before using the WIXI do not think so, I had changed the oil previously two different times at 300mile intervals. Cut the filters open the other filters did not do this. I am going to dig it out of the trash and check the date on the can.
It’s a known M+H problem. We call them poppers in the oil filter forum. Sometimes the glue breaks apart and gets through the bypass valve or center tube and ends up in the engine.
Yes, please let us know. ThanksI am going to dig it out of the trash and check the date on the can.
No those are good. We see them in M+H made Wix, Purolator, and Motorcraft mostly. Rarely in other brands.
2021.07.02Yes, please let us know. Thanks
