Double roller edelbrock, and we're going 4* advn the crank, 2* adv on the cam
Hopes to bring peak torque/torque curve a bit closer from idle, since I have rpm limits of 3000.
The oil pan and gobs a **** that fell down, I just dump diesel fuel in it until it poured out clean. Good enough.
Valve covers I pulled, vacummed what crud, and sent it. The little sticky gumbo boogers easily dissolved in used motor oil between my fingers. So I plan to run thinner oil, that way if the screen does get overwhelmed, it won't go totally dry and end up with pump starvation.
Some runny 5w30 or 20 through easily 2 or 3 oil filters, cut and examine the catch for progress, then eventually end up with 15w40 or its 43 year old diet of 20w50.
Next couple of weeks I hope to finish everything else and touch it off with some spark.
