I've been thinking lately. I've been looking at used vehicles. The ones with verifyable maintenance records in Carfax usually will be the ones the dealer won't cut a deal on. The ones with no maintenance activity in Carfax they will wheel and deal on.
There are few exception to the above. However, the crux of what I'm thinking is, after aquiring a used vehicle with no records and then subsequently doing oil analysis what can be revealed about the unkown history of the life of that engine?
Will the oil analysis only show real time issues? Will it indicate that previous oil changes weren't done timely? Will not so good wear numbers indicate abuse from previous owner?
At a novice level I can interpret a used oil analysis, but what about an engines past can actually be determined from them? Any insight to this would be welcomed.
