Hi everyone!
I'm owner of a 2004 Toyota Corolla CE with 5 speed manual transmission.
The car 86992 miles so far. Body his rust free.
I'm 27 years old and I did just buy my first house.
I know Corolla his a very reliable car but I'd like to avoid buying a new car for at least 10 more years and 15 if possible. House cost much more than appartment you know
My driving habits his about 70% highway 30% city, 280 miles a week. I'm living in Quebec, Canada so it's very cold on winter and very hot in summer. Here his the complete maintenance and repair so far on my car and I'd like to know if I should do or check something to keep the car running like new for much more year to come and at wich mileage I should do those check up.
-42 995 miles (Changing water pump + belt)+(Front brake pad and rotor)
-48 061 miles (Changing O2 Sensor Bank1)
-48 849 miles (Transmission problem, replacing Bearing input and output rear)
-55 302 miles (Replacing rear brake pad)+(complete suspension replacement. Tein Coil + Tokico gas Shock)
-61 789 miles (Radiator Flush and changing coolant with Amsoil Propylene Glycol, Transmission flush with Amsoil engine and transmission flush and then filled with Amsoil 75W-90 Long Life Synthetic Gear Lube, bleeding brake system and filled with Amsoil Dot3, flushed power steering fluid and filled with Amsoil power steering fluid)
-74 872 miles (Injection system cleaning at Toyota dealers)
-80 481 miles ( Both Front Wheel bearing changed and then the car get aligned)
-82 890 (New NGK Iridium spark plug)
So far this is the major repair I had on my car. Since the car his new oil change have been change every 5000 miles on dino at dealer and then at 40 000 miles every 10 000 miles with Amsoil 0w30 SSO + Amsoil Ea oil filter.At every oil change I'm cleaning up Air filter and changing it if needed with Oem air filter (Denso). It also received each year body rust protection.
Thanks for taking the time to read and sorry for my poor english, I'm a French Canadian.
(As you may noticed, My mechanic use Amsoil product, this his the reason why my car his Amsoil everywhere, so please don't start a thread about Amsoil)
