I have a 2002 VW Jetta TDI with 306,900+ miles and counting. It runs like a charm and I'm doing my best to make it last me indefinately.
I've used a few different oils in it since I've owned it (I bought it used with rather high mileage) including: Mobil 1 TDT, Rotella T6, Amsoil AFL, and am currently running Amsoil DEO in it. The 5 speed manual tranny is filled with a hair over 2 quarts of Amsoil MTG 75w-90. The engine OCI is always 10K miles. I'm going to start doing the Jetta annually weather it needs it or not.
I've kept obscenely detailed records on oil, fuel, maintenance etc. The oil that got me the absolute best mpg was AFL. It solidly beat T6 and TDT by at least 2mpg. I just put DEO in and am hoping for similar results.
I've had really good luck with Amsoil in the past and decided to go to Amsoil exclusively in all of my vehicles and engines.
VW TDI: DEO
Scion xB embarrassment: ASL
Toyota Highlander: ASL
1977 Ford F150 (Cummins 4BT) DEO
2007 CBR600RR: MCF
2002 Honda TRX450 Foreman: MCF
2010 Harley FLHTK: MCV(engine)/SVT(transmission)/ATF(primary)
Mowers/Generator/pressure washer/etc: Whatever's left over
Honda ATC 125 3wheeler: a mix of pee and dirt
The pull start stuff doesn't seem to care what I use. Out in the garage I've got a little bit of Rotella 15w-40 dino, a gallon of T6, about 1/2 gallon of M1 5w-30 and a quart of mystery stuff I have no idea what it is. This stuff goes in the small engines once a year regardless of use. Once it's all gone they'll get leftovers like they always have in whatever weights they happen to be.
The Harley has a heavily modified 103 inch air cooled engine and the last time it had something other than Amsoil in it was when it was on the showroom floor. 21,000 miles and absolutely zero issues. 10K OCI with it as well using MCV.
No I don't "work" for Amsoil. I just like the stuff. If you don't that's fine, just keep it to yourself. There's probably a lot of stuff out there that's just as good. I don't have anything against M1 or T6, I've used a lot of both in the past with great results, I've just decided to change to one brand for all my stuff and I'm sick of Wally-Mart.
VW TDI: DEO
2007 CBR600RR: MCF
