- Joined
- Jul 15, 2023
- Messages
- 1,674
A broad sweeping statement was made: that slower, heavier projectiles are less likely to overpenetrate walls. This is a statement about odds and tendencies, not absolutes.Well, tell that to the guy who succumbed to a 115gr 9mm bullet wound that traveled through 2 walls, and the wooden headboard of a bed, from an adjacent apartment. Or the one who collected a 62gr bonded tip .223 round in his ribcage after it traveled through both sides of the singlewide next door and into his. But I digress. Incidentally, those three authors that I listed back up their opinions with real world testing and are considered experts in the field of ballistic performance. The first 2 were also LEOs and have probably seen their fair share of "real world test results".
Not going to continue on with this as we can be here for years picking this topic apart. However, as @dubber09 states, what's beyond your target, and whether your ammunition can reach past that and cause damage is a major concern. And another aspect that most don't take into account, the legal ramifications if it does. This is why one should choose wisely based on the environment it's intended to be used in. And of course, as @Astro14 so succinctly put it, DON'T MISS. That increases the chances of causing unintended damage exponentially. So that involves training. And training the way you would if placed in that defensive situation to achieve a positive outcome.
I think the horse that is getting a beating is long dead. OP got a lot of great options to mull over. I think he will take all of the advice here into consideration and make a wise choice.
Anecdotes don’t mean much in the context of broad statements and likelihoods. That being said, 9mm is relatively slow and heavy in the grand scheme of things. And a 62gr bonded 5.56 is not the lightest or least penetrative flavor. Compared to a HP 55gr, yeah, it’ll go through more material.
There are no guarantees no matter which caliber is used, but that doesn’t mean this topic should be ignored, or worse, that people should do the exact opposite of best practices.
I’m going to press on this because people’s safety is involved. The fact is, if you want to lower the likelihood of wall penetration (again, this is never a guarantee), then source lighter and faster projectiles.
- #4 buck over #00 buck (good choice)
- 45-55gr hp 5.56 over 75gr (fairly good choice)
- 65gr 9mm over 124gr (but almost all pistol rounds like going through walls)
- Fragmenting rounds designed for penetrating less likely the 162gr 45 RIP in the video below.
And here’s another test:
