So I changed the oil in the taurus. Before with the Quaker State Ultimate Durability when I would check the oil, the oil would always be right where the oil level was at, right on the full mark. I'd pull it out, wipe it, and pull it out again and it was always the same spot. Now with this quickie lube universal eco ultra syn blend, when I first check the oil its half way up the dipstick the first time, put it back and pull it back out then its right at the full mark. Does anyone know why its half way up the dipstick the first time I pull it out? This is after it was parked over a day on level ground. Is this common? I about blew a gasket because I thought they overfilled it alot.
