Because of the many good reviews here, I have pretty much decided to try Havoline when I dump the factory fill in my Honda V6 VTEC.
I was looking at the VOA charts for various oils and noticed that the Havoline 5W20 formula has 406 units (or whatever 406 stands for) of Molybdenum. Most other oils have no where near that number (except Redline oils which post figures in excess of 600). In fact, some oils have zero moly. Another oil I considered, Motorcraft 5W20, shows only 33.
This does not seem to be the case with all Havoline weights however, as the 15W40 for example shows 93 moly content coming out of the bottle. I understand every manufacturer puts together their own formula package in their own way but why is it that this particular brand oil and in this particular weight has soooooo much more of this additive than nearly every other oil on the planet?
BTW, a guy at the Honda Ridgeline forum had his first oil change at 6863 miles (he went by his oil life monitor which is what the manual tells you to do, even with the first factory fill). He had a used oil analysis done of the factory fill and molly was shown as 385 which again, is much more than nearly every other oil (I understand the Honda factory fill is made by ExxonMobil but don't know this to be a fact). Maybe Honda's V6 engines like lots of molly?
