Your posts were a crazy jumble of disjointed sentences.
Was this your first oil change in this car?
How on Earth did you settle on a noise your engine being an "ADBV noise"? That'd be a first.
An ADBV is a pliable flap washer which is supposed to prevent back-flow upon shutdown. One making noise has never been mentioned.
One thing I believe is that some work better than others.
Those 2.5l Subaru engines are known for the noises they make. And thank you for taking 18 posts to tell us what engine you have.
Any chance of telling us the year of your car or how old it was when you got it or if you know it's service history?
Details in thread starting posts really help.
A pal bought a noisy 2001 Forester from a neighbor. It didn't have 60K on it but was a typical "bad Subaru".
He indulged a lifelong dream to solve engine noise by filling the crankcase with transmission fluid and letting it idle for 15 minutes. It didn't change a thing.
I told him that the harsh solvents of earlier fluids had been omitted decades earlier. I learned that here. He did it anyway.
A word on ADBV if I may.
We had a run of the Saab 2.3l 4 cyl. engines in my extended family. The spin on (aka canister, aka can) filter was side mounted on the block.
LOTS of oil changes were done on those 7 Saabs over 18 years.
When you unscrewed the filter, the oil in the top of the engine would drain out. It had been held there by the ADBV obviously.
Sometimes the ADBV worked and sometimes it didn't. If no oil followed removal of the filter it's safe to conclude the ADBV didn't do it's job.
Note: I always performed oil changes on a warmed up/recently shut-down engine so there was no chance of "overnight leak down" or some such.
I didn't have resources to set up an experiment involving every brand of filter out there but I can tell you the AC-Delco product worked every time. Others would too. Some appeared to have no ADB effect.
Using a Subaru filter in your Subaru is smart. Fram Ultras are ultimately praised here. I use one on my truck.
Some later Subaru models have high mounted filters so any ADB function is accomplished from within.
Some oils are "quieter" than others. There's a lot to know.
Hi Kira. Yes, a lot of firsts. First oil change, yes that is true. (To me on the car. It sat awhile) First Subaru. First time using Mobil 1. First Fram (Ultra.) First Fram before that. First new oil filter on it before that. First time thinking of using an engine flush product, as opposed to transmission fluid or other solvent. So more than a few firsts.
I have a 2000. I believe they call it an EJ251. No head gasket problem so that's good ..
This filter mounts vertical, straight up and down. Presently got the Fram Ultra on it. Previous filters, I had a car with a canister filter.. on the top. Always messy. Also had a truck with it remote-mounted. Not sure the last time I had one where it was on the side.
I at first thought maybe there was a ADBV issue, then perhaps a PSID drop issue, as filter size, as mentioned, the greatest the size, the longer oil should take to fill it. Now, gravity helps this one fill; it has to fight gravity to come back up to lubricate.
If the ADBV was maybe stuck closed and causing the initial lack, that is what made me flip out and think oh, there is a problem. Sounded like rod knock. Sounded the same as the Piston Slap (much more likely what it was) because lifter tick has pretty much gone away. Which lead me to come and ask the question, and I chose to trust wisdom and not use the flush.
Quick summation, somehow someway, an overfill condition has appeared to quiet the noise. I then thought maybe I had a oil lubrication/lubricity issue. Mobil 1 in for less than 100 miles and I'm noticing the engine seemingly shut off smoother; which also probably makes no sense.
But I believe it is cleaning sludge.
Will look for the color of the oil when I get home.. all good?
Yes, it was.
Yesterday was Oil Change #1. 162,875. Filter changed Fram Ultra ~162,800.
No large chunks came out. I don't think I saw any, actually. Maybe some small ones but not for certain. Oil smelled a little more like gas than I would have liked but it is a new fill in there now, as mentioned, primarily Mobil 1 0W-30.
