Why not Valvoline Restore and Protect for average Joe OCIs?
It does not seem like any other oil on the market is able to clean what Valvoline Restore and Protect is able to clean.
Sounds like it yes. Then again my engines aren't full of crud at the moment because I maintain them properly. If your car's engine is burning or puking oil, run it for 4 OCI's and hope for the best.
If your engine is running well without issues, there's better stuff out there IMO. Just me though. To each their own(y)
Fair enough but if I may ask what are you currently using? My reasoning is that if its a typical oil then Valvoline Restore and Protect can provide more benefits because why not. Of course, I am not arguing your engine is clean however you never know what your rings may have on them
Ditto - you don’t know what your rings and pistons look like and could have a fair amount of hard carbon build up as a result . This should be the main reason to use Valvoline Restore and Protect over other oils (at least through 4 - 5 OCI’s). Valvoline Restore and Protect also shows excellent wear numbers . If I didn’t use Valvoline Restore and Protect 5W30 I would be back to using Mobil 1 ESP 0W30 ESP.
In my honest opinion Valvoline Restore and Protect is probably the right choice for most drivers. 5k oci’s and never having to worry about stuck rings.
I’m one that did have a spotless engine but dirty pistons. Valvoline Restore and Protect saved my butt. It’s a game changer.
A couple long discussions here on this topic, but the 25 other threads on this oil often discuss it as well:
The reason I keep saying Valvoline Restore and Protect is because it does everything your typical oil does but it can also actually clean deposits, which most other oils are not really proven to do. So why not run a oil that is likely cleaning your engine better then what you were running before while still giving the same protection
I've been running it in three vehicles as their standard oil. They they first got on the Valvoline Restore and Protect at 5k, 18k, 60k. It is very good oil. I feel that prevention is better than trying to fix something later on. Keep things clean from the get go. I change the oil every 4-5k depending on which vehicle.
I can guarantee you my engine is cleaner than an Hospital floor and no Valvoline Restore and Protect was involved.
Unless you have taken apart your engine and inspected the pistons you most certainly cannot guarantee how clean it is inside. You’re merely speculating
It’s kinda sad how many people I see on here and elsewhere on the internet who want to discredit this oil without even having tried it 🙄
I’m glad you are so sure of your engine condition. 2 things will likely happen in the fullness of time:
Those that thought RP was the best all around oil will find that to not be true, and:
Those who say that they will never need it or use it will one day find that it does work and they could use it’s attributes.
The way of BITOG for as long as I’ve been here.
Most ideal choice if all your vehicle calls for is a SQ/GF-7 oil for OEM drains. My next off-shelf best choice is one of the Mobil 1 grades.
Valvoline Restore and Protect is a game changer, no doubt about it. It's slow to sink in with some....
i am not discrediting this oil, i have zero use for it. my 2024 Mazda CX-5 Signature has been fueled with nothing but Shell V power since i took possession at the Dealer. i do 6500 Km OCI with Pennzoil Ultra Platinum 5W-30, or Mobil 1 0W-30. i drive on average between 3000 to 5000 kilometers a month. it is inspected every 2 Months. maintained religiously at the same shop i have been doing business for 29 years. when they changed the plugs at 62 000 kilometers like the owner manual ask, they were so clean, the mechanic was almost troubled. he measured the gaps. they looked brand new. why would i use Valvoline Restore and Protect? what benefit there is in my situation?
I don't see why Valvoline Restore and Protect shouldn't be the go-to oil for the average Joe with regular OCIs in mind
As most of us already know this Valvoline Restore and protect cleans better then basically anything else in that price range. Valvoline has even stated its good for up to the vehicle OLM/OCI and that its one of the stoutiest oils they offer.
From what I have experienced and from what we have all read about it on the forum, it really seems like a no brainer for the average driver who just wants a standard OCI oil.
Before anyone jumps in and starts arguing hear me out.
Someone trying to get 20k miles out of a oil change is not a average joe so that does not apply here. Someone running a twin turbo V8 and tracking it every weekend also is not a average joe. Same goes for people who run a certain oil because they think the engine runs quieter or smoother on it, that is not who I am talking about.
I am talking about the typical guy who does 5k mile OCIs or just follows the OLM, goes to Walmart, and grabs Mobil 1, Castrol Edge, Pennzoil Ultra Platinum, or whatever $30 jug is on the shelf. For that person I don't really see why Valvoline Restore and Protect wouldn't be a better option.
In simple terms the engine is not going to care or even notice if it has Mobil 1, Castrol, or Pennzoil in it. We have seen over and over from Blackstone and other oil analysis that the wear numbers are basically the same for normal OCIs. At that point it really just comes down to personal preference.
The reason I keep saying Valvoline Restore and Protect is because it does everything your typical oil does but it can also actually clean deposits, which most other oils are not really proven to do. So why not run a oil that is likely cleaning your engine better then what you were running before while still giving the same protection.
And again just to be clear, this is not aimed at extended OCI guys, track cars, or people dead set on a certain oil for subjective reasons. For the average driver doing normal oil changes, Valvoline Restore and Protect just makes sense.
Kindly,
I think you are definitely pointef in the right direction. I see nothing wrong with your analysis. Its not for certain oem requirements or weights but it would be great on lots of small gasoline domestic and asian vehicles. Where it loses people is probably on PRICE. That's still on everyones mind at some point. MARKETING would do the trick but unfortunately the red bottle maxlife kinda took the wind out of anyone seeing anything else. People are driving 🚘 that have lots of miles and are more concerned about keeping the leaks maintained and most of the time the red jug is under twenty dollars 💵 so that is where it is at. Ever go to Walmart just to get out and see whats the hype? Its mostly high mileage oils, Lucas Oil Stabilizer and the Blue Devil RMS sealer. I think Walmart offers the Valvoline Restore and Protect service for 65$ here in El Dorado. Its a fine oil and I use it back and forth with Valvoline Extended Protection High Mileage.
After this next oil change, its gonna be short oci and cheap as this car is on its way out.
Kindly,
For my father inlaws 15 year old car with 100k miles and the engine is still clean as a watch on the inside, probably keep using motorcraft or whatever is cheap.
Valvoline Restore and Protect seems like it's more for people who fell victim to oem 7 to 10k oci and are now paying for it also those who have bought used but neglected vehicles.
When considering the oil choice for my new truck, I emailed Valvoline about this directly. I gave them the vehicle info, a 2025 F150 with the 5.0 V8 engine, and said I was looking for the best option for wear protection and cleanliness at 5000-mile change intervals. They stated, very clearly, that Restore and Protect is their top performing oil and outperforms all of their other offerings. It was their only recommendation. With that information, I began using it in my truck with 500 miles on the odometer and it has been doing great.
