Ok, let me get this straight:quote:
Originally posted by Al:
When do you determine that the oil is "clean" or "not clean"
Visually the darkness you see may be mild oxidation, mild soot and other things that may only have a micron size less than 1 micron. On the other hand you might us your "visual test" on another engine with very tight rings where tha oil may be wonderfully clean and yet has 100 ppm of lead and iron floating around (with particle sizes of 10 microns. )
So how did your "visual test work"
The visual test is about as useful the Jiffy Lube concept of changing oil every 3K .
I'll give you another example. My 01 Sentra keeps clean oil forever it just doesn't get dirty. Due to warranty considerations and "feel good" stuff-I'll change it around 6K miles.
My son's Cavalier will go over 11K miles. Oil is very dirty.
Shaeffer's 5W-30 Pure syn on both cars:
Cavalier(11100 miles)lead-7, Iron-13(Dirty oil)
Sentra (6700 miles)lead-11, Iron-29 (clean oil)
These are real life numbers. What say you??
The dirty-looking oil with 11K mi. on it is showing only half the wear particles as the clean-looking 6K mi. oil? Sounds to me like you need to find another lab to do your testing!
(Sorry, couldn't resist
To me, "clean" oil is synthetic with around 3000 miles or less on it, and looks clean on the dipstick. For dino, I'd only go 2000 miles and looking clean.
When you take an oil out to 10-12K, you run into the situation like 3MP's well-intended long life study where you've done quite a bit of topping up and this is going to throw the wear figures off quite a bit. Kind of like giving the oil a "face-lift" to make it look better.
I'm not saying you aren't getting engine protection in these kind of extended drains, just that you would have a better situation as far as suspended wear particles go by getting them out of the engine every 3K or so, and keeping the oil always brand new (so to speak).
[ August 22, 2003, 02:26 PM: Message edited by: Rexman ]
