I just learned that my new (to me) 05 Taurus does not have a drain plug on the automatic transmission. This seems strange and inconvenient. Apparently the way you change the ATF is to take most of the bolts off and tilt the pan until the fluid pours out over the lowest corner. Crazy and possibly messy -- I'll let you know.
My only other experience with changing ATF has been with Hondas -- which have drain plugs. Is this a domestic vs import thing? Inline 4 vs V-6? Is either Ford or Honda the oddball here?
Since a drain plug makes it much easier to change the fluid, what would be the reason to omit it in a car's AT pan?
