Why no Amsoil ATF for VW auto trannies?
Alabama
"What is the fluid requirement?"
All I know about the fluid requirement is that it is VW Part No. G 052 162 A2
Isn't that a lifetime fluid?
The problem with the aftermarket is cost vs profit.
Who will buy certain ATFs when the transmissions are filled with "lifetime fluids"? Where's the market???
If you don't want to use the required Pentosin ATF1 or Esso LT71141, then use Pennzoil multivehicle or Redline D4.
unDummy,
Yes, it is technically a "lifetime" ATF. I don't like that fact one bit, either. Shame on all manufacturers who install "sealed" transmissions. A Pox be on their houses!
Is Pentosin ATF1 the same as VW G 052 162 A2?
If so, I know where to order that online.
Thanks in advance for your reply.
p.s. how did you get your user name?
