Originally Posted By: CATERHAM
The evidence would suggest that TGMO is a more expensive oil to make than Mobil 1 0W-20.
What evidence? The AFE oil has trinuclear moly and is 30+% PAO, both of which aren't cheap. In comparison, TGMO uses (inexpensive) group 3 bases and we have no PDS for it so we don't know what the other specs for the product are.
Why doesn't Mobil sell an OEM version of what they make for Toyota? I'm sure Toyota wouldn't mind. Nippon Oil certainly did in their ENEOS 0W-20 at twice the price of TGMO.
Well, ENEOS is Japanese (like Toyota) and likely shares the same VI fixation, which as I noted earlier, appears to be a Japanese thing.
I don't think Mobil sees a compelling reason to produce another 0w-20 that is thin enough that it probably can't be recommended for Ford and Chrysler applications, which their current 0w-20 products CAN, for no other reason than it having a higher VI.
No the reason would appear to be that to price is profitably they would have to charge more than what they already charge for Mobil 1 0W-20. And that just wouldn't work for a host of reasons.
Based on what? Both Mobil 0w-20 products are heavy in PAO, which is expensive. TGMO is entirely group 3. How can you posit that it is a more expensive product here? Unicorn tears that Mobil buys on the black market from Russian operatives who secretly run a farm in Siberia?
No I think one can safely conclude that TGMO 0W-20 is an expensive oil to make, not just because Mobil doesn't sell it under their own name but also because very few formulators who make an API 0W-20 choose to make a high VI version.
It's a business decision, and the cheaper you can make it, the higher the profit.
It's a business decision and aside from people on BITOG, nobody has a friggin' clue about VI. I doubt it is more expensive to make, and you seem to be pulling that "factoid" straight out of the air IMO. Based on base stocks alone, it is significantly cheaper to base TGMO than it is the two Mobil 1 0w-20 products. I think the fact that it is too bloody thin to recommend for many 5w-20 applications is likely the reason Mobil doesn't make a product like it, and this is also likely why their own excellent 0w-20 products are intentionally heavier.
Your sole case that Mobil 1 is more expensive to make is based on the up to 30% PAO content. As far as the AW additive content including moly it's higher in TGMO.
Others have postulated that Mobil is using GP III+ base oils to make the high VI TGMO and of course you've omitted the main difference which is the new (and undoubtedly expensive) very high VI PMA VIIs that TGMO is made with. The end result being that not only does TGMO have a much higher VI (and way lower KV40 spec') but it's no more shear prone if not more shear stable than Mobil 1 0W-20.
So there's that, plus the fact that only the OEMs are formulating oils with this technology. The one or two others that do charge a lot for their shear stable very high VI oils.
As to your remark that "nobody has a friggin clue about VI" you're absolutely right. But they also don't have a clue about any other oil spec' including KV40, KV100, MRV and CCS. But what people do know is that 0W-20 oils are supposed to be lighter than 5W-20 oils and they are not just at extreme cold temp's but more importantly due to their higher VIs at all start-up temp's. And although you like to dis' VI, that's the main advantage Mobil 1 0W-20 has over a 5W-20 with it's 20-25 point higher VI especially compared to a typical 5w20 conventional.
And what expert source are you relying on to conclude "the fact that (TGMO) is too bloody thin to recommend for many 5W-20 applications"? The latest version of TGMO 0W-20 packaged in the States actually mentions on the bottle it's suitable for when the 5W-20 grade is specified.
