Originally Posted By: d00df00d
Originally Posted By: JoeFromPA
I've always read that Michelin's construction techniques are typically the best in the industry insofar as balancing, integrity of the tire carcass, etc.
So I guess my question is: To those educated in these things, any reasons for or against this way of thinking?
I can't provide reasons, but I can lend support: Look at virtually every single successful hypercar made in the past 10 years. Almost all of them use Michelin Pilot Sports: the McLaren Mercedes SLR, the Koenigsegg, the Porsche Carrera GT, the Bugatti Veyron, the Pagani Zonda... The only notable exception AFAIK is the Enzo Ferrari, but that's because of Ferrari's close relationship with Bridgestone at the time of the car's development.
Michelins are also among the top choices of cars one rung down the ladder from those, competing only with the very top tires from Bridgestone and Pirelli for fitments on Ferraris, high-end Porsches, and the like.
If you want a good all season tire, you should look at the Bridgestone Potenza RE960AS Pole Position. I had it on my old car, and a friend of mine is running it on his own '06 Civic Si, both year-round, and both with extremely favorable results (to put it lightly). However, if you're looking at a similar Michelin tire, I wouldn't steer you away.
I can also assure you, for what my experience is worth, that the top tires are expensive for a reason. They will out-grip, out-handle, out-ride, and out-last the cheaper ones almost every time; the only exception is when a cheap tire does one or two things very well (e.g. grip), in which case it does other things very poorly (e.g. ride quality, noise). If you're thinking of stepping up to a well-reviewed tire from a great company, you won't be disappointed.
The tires for hyper cars are not chosen for coping with icy hills in Pennsylvania. Much tire rating depends on the goals of whoever is rating the tire. I think one of the best tire choices I ever made was when I bought my first set of radials in 1966. I went with Perellis over Michlins. I buy tires knowing I have to get around in all kinds of weather, not to play around when the roads are smooth and dry.
