Respectfully disagree.Manual transmissions is a greatest thing to prevent people from texting while driving .
Why make it easier by standardizing a standard shift would only make it easier for them to text
Tom
You bangin' gears on the highway?
Tom
I really liked those.my Chevelle was a 3 on the tree.It wasn’t complicated when I first started driving on one with a three on the tree back in my high school days.
Not sure why an MGB has reverse as left and down, which has a stiff spring that needed a gentle slap to get it to go left, and my Midget has reverse right and up, guarded by having to pull the gearshift straight up. Maybe Triumph just had to be different from MG and then British Leyland ended up sticking the Triumph Spitfire drivetrain in the Midgets.
MGBs and Midgets both had left hand and right hand drive versions. The drivetrains for the UK and US versions were pretty much the same, other than the smog equipment.Opposite because driver is on right hand side instead of left like the US?
I watched dude a steer with a knee while cycling through songs on his phone and shift just fine. Driving a manual doesn’t remove any distractions.Manual transmissions is a greatest thing to prevent people from texting while driving .
Tom
I had a 1965 Ford Galaxy 500 2-door with a 289 that had a 3 on the tree. Converted it to 3 by the knee (JC Whitney floor shift kit) .Three-on-the-tree disappeared in new vehicles over 40 years ago. Some mid-1970s American pickups were the last to have those.
There are many gear patterns for manual transmissions, which seems could cause transmission damage or in a worst case a stall, a crash, etc.
Why has the industry never compromised and come to some gentlemen's agreement on a standardized design? Other items, like seatbelts, have standards. Surely one pattern is a superior design for speed and efficiency and safety? The problem comes if you have several manual cars or have to drive many (like a valet, or car dealer, etc.). You have to then relearn where the gears are.
To me this seems like the most logical design. Reverse pointing backwards (the direction you want to go), and to the left of the low gears so as to not inadvertently go from higher gears into Reverse and blow up the transmission and cause an accident. (I think modern cars lock it out, but it still makes sense.)
I had a VW that had the R off to the side, and required a downward push to then put it in R. You could not inadvertently put it into R without a downward push. I liked that feature a lot.
But you have other designs. Going from 5 to R would be a catastrophe.
This is at least safer, but not as intuitive IMO.
I hope your other car isn't a 6 speed...
How about a shifter that came out of the dashboard? I knew someone who drove a Metropolitan with a shift like that.
Here is another example.
