There are many gear patterns for manual transmissions, which seems could cause transmission damage or in a worst case a stall, a crash, etc.
Why has the industry never compromised and come to some gentlemen's agreement on a standardized design? Other items, like seatbelts, have standards. Surely one pattern is a superior design for speed and efficiency and safety? The problem comes if you have several manual cars or have to drive many (like a valet, or car dealer, etc.). You have to then relearn where the gears are.
To me this seems like the most logical design. Reverse pointing backwards (the direction you want to go), and to the left of the low gears so as to not inadvertently go from higher gears into Reverse and blow up the transmission and cause an accident. (I think modern cars lock it out, but it still makes sense.)
I had a VW that had the R off to the side, and required a downward push to then put it in R. You could not inadvertently put it into R without a downward push. I liked that feature a lot.
But you have other designs. Going from 5 to R would be a catastrophe.
This is at least safer, but not as intuitive IMO.
I hope your other car isn't a 6 speed...
