Originally Posted By: Pablo
Originally Posted By: Lyondellic
I am wondering if folks in colder climates would benefit from an ATF resembling engine oil (i.e. 5W-20)? I know that MTF is usually XW-XX, so why isn't ATF the same way?
I don't exactly follow - do you mean why isn't ATF labeled like motor oil, or why doesn't ATF behave like motor oil?
I can assure of why it not labeled 0W or 5W-10 or 20: So people don't put it in their engines. And yes ATF has "multiweight" viscosity.
I think you may have answered my question. Based on the label information, one could easily assume that ATF is a straight weight fluid. Most engine oils, however, contain additives that help them flow at low temperatures, hence the XW-XX numbering.
According to your post, ATF is a multi-grade fluid it is just not marked as such. If this is correct, then you have answered my question.
