I stopped using Rain-X many years ago because it gummed up the squirters. And I use the minus 30 stuff I buy it Napa but I add a few ounces of 409 cleaner to it. If you ever get splashed with a puddle that has a little bit of tar to it or Grease from the road which can happen when a vehicle going the other way hits a puddle, having a little bit of 409 in the mix goes a long way in quickly removing the oil filim them from your windshield. Without it even good wipers can't get rid of it quick enough.
My test in whether or not windshield washer fluid has enough detergent in it is to Shake The Jug and see if it Foams up on the top of the fluid. I always add enough 409 so that it will foam up.
