So, I did some research and still can’t find any info this is even being tried in the way I see it in my head. MB makes a diesel hybrid, and there are two other cars with diesels but they put diesel driving one set of wheels and EV driving the other (link will be at the bottom).
But, why have we not seen a full EV powertrain with essentially just a diesel generator to extend the range? Meaning, the diesel would not be connected at all to propulsion, it would just generate power. This way, you could have a small turbodiesel that runs at a constant speed, so efficiency & BSFC could be maximized, and the genset could be tailored as well and could likely even provide 100% of the needed energy if the car was in the city.
It could be programmed to either come on at a given battery % like if the battery is nearly dead, or it could also be programmed to start up and run on a time-based schedule to top-up the battery, or even prevent starting if the battery was above say 75%. This would not only maximize range, it would always keep the driving experience 100% EV since you’re never coupling drive systems.
Plus, since you could probably achieve all of this with example: Kohler 3-cyl turbodiesel, sound deadening & NVH controls would be simple since it would operate at same speed all the time. These are already Tier IV compliant, so even greenies don’t have much to complain about.
Anybody read/heard anything why this approach hasn’t been tried? Seems like you could take one of the existing EVs that drives only one end, slap the Kohler/genset and a 5-10 gallon tank in the other end, and have an EV that could easily exceed 1000 miles between the need to plug it in OR refuel it??
https://www.greencarreports.com/new...why-they-dont-make-as-much-sense-as-you-think
https://kohlerpower.com/en/engines/product/kdi1903tcr
