OVERKILL
$100 Site Donor 2021
Originally Posted By: Virtus_Probi
I did notice that when I could find side by side test results on an oil maker's website, the 0WXX NOACK numbers were generally worse than for the 5WXX oils...that would definitely concern me.
+1
Unless you live in Moosejaw Saskatchewan, no need for 0W & definite drawbacks on stability.
I think the majority of Euro OEM's would disagree with you given that a very large percentage of their approved lubricants are 0w-xx. Stability-wise, they also have NOACK below 10% (much lower than many 5w-xx non-Euro oils) and most have proven to be very shear stable as well.
Sure but posters on this thread don't live in Europe & typically access to full PAO sans VII is scare, so my point is valid for like vs. like formulations.
Typical access to any oil sans VII is next to non-existent if you read the recent thread about it. Two lubes right off the top of my head that are Euro grades with high percentages of PAO are Mobil 1 0w-40 and Castrol 0w-40.
A majority PAO "regular" PCMO that is readily available is Mobil 1 Extended Performance 0w20.
+1
