Why doesn't 10W-30 meet dexos1 ?
Clovis, CA
I'm curious as heck. Why doesn't it ?
Because that is not an allowed viscosity for GM vehicles requiring Dexos. At first only 5w30 was recommended and could be Dexos.
Why not ?
Because the owners manual says so?? For my truck only 5w30 is allowed unless in extreme cold 0w30 can be used. That's it.
If the OEM spec'd 5w30,nobody will spend the money to approve a 10w30,or a 10w40,or a 5w50 or....
Originally Posted By: Garak
That would be why, being the diesel spec. As far as I know, every dexos1 oil is also GF-5.
I have to swing by the Opel dealer when i'm home and check it out. IIRC Dexos 1 is seldom in Germany, most GM use Dexos 2 inc the gassers.
Example.. GM 1.4 turbo is a 0w40 engine with 5w30 as second choice if 0w40 is unavailable.
OPEL
Modell
Astra 1.4 16V VVT Turbo ECOTEC Automatic (Astra J - A14NET 103kW)
Jahr 2010-
Motor (BT) (A14NET)
1. Wahl Mobil 1 ESP 0W-40
2. Wahl Mobil Super 3000 XE 5w30
Things are evolving to the point where 5w30 is a baseline spec for motor oil moat GM vehicles made in the past 15 years. If it isn't the baseline, then it is an acceptable weight.
It is the default weight for both of mine.
Decades ago, it was 10w-40... then it went to 10w30, and now 5w30.
And it likely won't stay at 5w30 either.
So... looking at this... why would there need to be a dexos approved 10w30. Considering that not many people would be using it, there's not a whole lot a need for standards and approvals. That's what SN and GF-5 is for.
As others have noted, for the same reason that there are no Dexos 1 20W-50s.
It isn't a grade currently recommended by GM for any engine requiring a Dexos 1 oil.
I'll ask a general question here:
Does GM even allow Dexos licensing of grades it doesn't recommend for use in its engines?
One big aspect of dexos1 is fuel economy. Most of the 10w30 oils out there are not energy conserving to qualify.
GM began to move away from 10w30 in the mid-2000's. My current Saturn (Opel/Vauxhall) Astra calls for a 5w30 meeting GM spec' GM6094 (related to low temperature pumpability. IIRC), but mentions nothing about 10w30. Like almost all GM manuals it says to use a synthetic 0w30 or 5w30 in extreme cold temperatures. Previous to that GM manuals said 10w30 was fine if it met the GM6094 spec as well, which most do.
Incidentally, Mobil 1 in Germany and Europe seems to want 0W-40 in that 1.8L engine while Shell UK calls for Helix Ultra 5w30...
OPEL
Modell
Jahr 2010-
Motor (BT) (A14NET)
I assume this is the exact same 1.4T that's in my Cruze.
I had wondered if Mobil 1 0w40 would be a good choice in this motor (after warranty of course) and now I see the answer.
I will have no problem using the 10w30 PU (warmer weather) that I scored at the AZ clearance late last year in my Cruze. I'm not concerned about the fractionally lower mpg...
GM only allows grades it uses in its engines, yes. The thing with dexos (do not capitalize the first letter, officially GM) is that GM gets about 9 cents per quart or liter sold ( yes, a racket...), therefore an oil company puts the dexos official symbol on a bottle, but also could sell the same formula in another bottle without the dexos symbol printed on it, and save the royalty (ransom?).
All SN/GF-5 oils I've seen, with exception to 10W-40 and 20W-50, are resource conserving. That means SN/GF-5 rated 10w30 is resource conserving. That being said, 10w30 over 5w30 is a moot point that has been hashed and rehashed many times on here. It's too easy to obtain dexos spec oils now to use 10w30 or non-dexos 5w30 over the dexos spec.
