Originally Posted By: turtlevette
Originally Posted By: Shannow
I'm interested in how oil pressure and temperature can be used to determine how the cam chains are faring with this overly thick oil...given that seems to be the reason for Ford's engineers getting it wrong in not specifying a 20.
Good point. The way I see it is can't give you any clue as to how the chains are faring unfortunately. Those two gauges tell part of a story, not the whole story. It's like going to the doctor for an exam and he checks your blood pressure, and temperature, and nothing else. He sees it's OK and sends you home with a clean bill of health.
If oil pressure and temperature can determine how the chains are holding up I stand corrected and would really like to learn how.
I don't think that's what he is saying.
And if the thick oil recommendation by Ford is to prevent chain noise, I'm really not interested in selecting an oil based on sound.
Or possibly chain wear. Oil pressure is one part of the equation.
Can't say I've ever lost an engine from oil from old fashioned "thick" oil but I've lost a few bottom ends from to thin.
I don't base my oils on sound either... But when cams are solid roller at over 700 lift you can't hear much
I respect your opinion on thin is best for everything, but experience has proven that isn't always true. Imo Ford has a reason for not back specing 20 in this engine since they did about everything else. That would be good enough reason to trust them.
You make some great points and in your posts and I personally follow many of those... I run 5w20 in a built 440 Mopar and a few modular 5.4/6.8s in our fleet well over 200k. There are some engines however that even with great oil pressure 0w20 and 5w20 can't protect even at sub 100c oil temps.
