Originally Posted By: KrisZ
Because in light duty applications synthetics are designed for extended OCIs and conventional oils aren't. It has nothing to do with synthetic vs conventional superiority.
If you look at heavy duty applications, there are all sorts of conventional oils that will spank most if not all PCMO synthetic oils in TBN and their ability to go the distance.
Also TBN is just one aspect of oil makeup for extended OCIs, there are other factors as well.
They do not necessarily "spank" PCMO syn oils, the TBN is relatively comparable, that's not the difference between PCMO and HDEO. HDEO's are designed with hard use and high temperatures in mind, so they are mainly more shear resistant with more anti wear additives on average. EX is T5 10W30, its rated SM due to higher than SN wear additives (while having a similar TBN to PP) and its not rated as resource conserving due to higher viscosity for a 30w, but SN is not its target, a hard working diesel or gas engine is.
The same can be said of the Euro oils though.
For the HTHS and anti wear additives it can be, but Euro's from what I have seen tend of have a lower TBN, not as much sulfur etc in their fuel so they don't need as much acid protection. Not the case for all but definitely the case for many. Castrol may be the one that I noticed that does have a higher TBN like US oils. I would say Mobil 1 0w40 as well but I am not convinced that oil was meant for euro as much as it was mean for turbo apps and high rev apps. Valvoline, Kendall, and the rest euro's tend to have lower TBN.
You have to look at the suite of Euro specs being met. In that vein, Mobil 1 0w-40, Castrol 0w-40 and all the other oils that have the same approvals have high relative TBN's and robust additive packages to cope with high stress, high power density applications and extended drains.
Now, there are other Euro approvals that differ from the above, like the low SAPS ones, which cater more to European fuel, but those aren't generally the ones being shopped on this side of the pond, the full-SAPS oils above are.
There are HDEO's sold in Europe that are the same way.
My point was simply an ad-hoc to your own in that the API approvals are irrelevant for the Euro OEM's and often the Euro lubes will carry an outdated API rating, if they bother to carry one at all.
I believe there are exceptions in both veins (HDEO and Euro oils) but that regarding the products that are generally available to us (like those already mentioned) that this holds true.
