Originally Posted By: Geo_Prizm
What manual have you got? Is it owners manual, Haynes, Chilton or factory shop manual?
I am thinking of replacing the filter in my 1994 Prizm. A245E is my transmission type, as far as I know Toyota used this transmission till 2006 or 2007.
I wanted to do it as you did, by just draining and re-filling.But there might be pieces,dirt trapped in the filter,a change might be better service.The only thing scares me is if the new gasket does not seal the pan and as a result getting leaks where there was none before the service.Any advice about dropping the pan,replacing the filter and sealing/putting a new gasket on the pan?
We have just the owners manual. My parents have not purchased a haynes/ chilton manual yet because they have not needed to do any work on the car (just oil changes).
If I knew their was a filter I would have replaced it. I have done it on a number of cars before and having a drain plug in the pan would make it much easier.
If you want advice on not getting leaks than make sure you really clean the area where the gasket will go and make sure not to over-tighten the bolts holding it on.
