'97 Civic, 92K Miles, 5-speed. SOHC, VTEC-E engine.
My question is: Did consumption drop because I gradually added 20 oz. of 20W-50 when topping off the disappearing 10W-40? Or dropped because that 20W-50 was Castrol dino and not the Supertech Conventional 10W-40 that was already in the sump?
When the weather warmed up recently, and ECT now typically 185-195 deg F vs. ECT about 177-185 in winter, oil consumption increased from about .75 qt/1000 miles to more than double that, running 5w30 conventional which is spec'd for the car. I did an oil change and put in 10W-40 Supertech Conventional. Here's how it played out:
(odometer readings)
191,310 - 191,864: took 22 oz = 1.24 qt/1000 miles
- - - - on 10W-40 Supertech Conventional oil.
191,864 - 192,200: took 10 oz = .93 qt/1000 miles
- - - - running with 15 oz. 20W-50 Castrol used to top off the 10W-40 during the 336 mile run.
192,200 - 192,384: no consumption detected in 184 miles
- - - - I'd added 5 oz at the 192,200 mark so it ran these 184 mi. with 20 oz of 20W-50 Castrol.
It had a rough idle and occasional misfires reported by the OBDII check engine light. No CELs after adding 15 oz. 20W-50 to the system, and a smoother idle.
I've been meticulous about tracking the ounces, parking in level spots, even letting it sit an hour or more before doing a final level check. The sump is too small and consumption too fast to let it go 1000 miles between topoffs. I must admit, I'm a detail guy.
(odometer readings)
