Why Cylinder Deactivation Can Cause Engine Failure (Honda)
I wouldn't bet on it. Change the oil with full synthetic Mobil 1 0w40 or 5w30 ESP at half the OLM to give the engine half a chance for a long life.
These VCM engines are notorious. IIRC I was one of the first to run into the issues and actually tore into the engine for a look see and repair, that was many years ago but posted here and took a lot of flack from the Honda gang.
I remember that quite well. You tore into what was thought to be a well maintained engine to unveil a nightmare.
You can actually have this "feature" deactivated PERMANENTLY though the CANBUS system, I'd definitely have it disabled if you have this engine. The only change is you MIGHT lose a few tenths of MPG, and the engine will be perfect for the long haul.
TURN THIS OFF!!!!
Is this something that can be done if ForScan if you have a Ford?
