Why are there so many wiper arm connection types?
It's like this with gas cap designs. I worked as an emissions Inspector for a while and I think there were 10 different gas cap testers. Why does every automotive manufacturer try to reinvent the gas cap? Ford has a capless design where the filler door seals against the opening.
I just hate it when I've got to install wipers for a customer and have to pull out the little instruction paper and figure out exactly which ones they have and which of the 8 adapters in the package I need... I feel like an idiot. I've memorized some of the more common ones, but we sell maybe 15 different brands and models of wipers, times 10 different types of wiper arm connectors... there's no way I can remember all of them.
Just think of the cost savings if there was 1 connecter type.
And guess who is paying for all these adapters that most of end up in the trash?
This was gonna be my next point. I'm no real steward of the environment, but all these extra adapters are super wasteful. We have an entire extra trash receptacle at work just for wiper packages and clips because there's so much of them.
What bugs me more than the adapters, is the design of most window defroster vents (which is related to how the wipers work). This is something most people don't ever notice, and something that isn't an issue 99% of the time, but when it is an issue, it sucks.
What you usually get is a defroster vent that's like a foot long, then there's a gap of a few inches, and then another long part, and another gap, and so on.
The problem is that part of the wiper blade rests over where the gap is, which causes an issue in the winter when it's cold and snowing out. The wiper will have a section (that coincidentally lines up where this gap in the vents is) that doesn't wipe properly, and you'll end up with a white crusty smear right in your line of vision that you can't get rid of, or worse a section that starts freezing up that causes the entire wiper to quit working.
It seems like I might be the only one who has ever been effected by this phenomenon or cares about it. They've been making vehicles for over 100 years, and nobody's figured this out yet? How about we make it so the warm air can blow across the entire length of the wiper blade, is that too difficult?
OK, rant over. Thanks for listening.
What I see commonly is the vents don’t actually point at the wipers, in my case it’s a few inches above where blades rest. Such a simple thing but yet missed in the design.
I use prestone yellow washer fluid which helps against re-freezing
At first I thought you were being a smart ass and suggesting to fill the washer tank with normal anti-freeze. I was thinking there's no way that can be right, so I googled it and found that Prestone does indeed make washer fluid.
Thanks for the tip, and I'm sorry I doubted you! I will be on the lookout for that stuff.
I was having my yearly Jetta safety inspection done and they came out and said I needed new wipers to pass. Internally I smiled and said sure go ahead. I was responding to emails from work and had the time.
I saw them grabbing adapters left and right. Calling several other people over, scratching their heads and about a half hour later they came back and said they didn’t have any wipers to fit it. I asked them how much the trico they sold were and were a decent price and I went out and took the adapter off of my old wipers and clicked it on to the new ones and popped them right in like a minute. The guy said man I didn’t think of that and didn’t charge for the wipers.
  • Like
Reactions: D60
Wipers remind me of remote hydraulic couplers on farm tractors years ago. About each brand of tractor had a different coupler.
Want to hook a John Deere disc of your neighbor's to your International tractor, swap couplers on the disc to plug the hoses into
the remote outlets on the tractor.
Most tractor brands finally went to ISO couplers for a standard fit. Auto brands need to take the same approach. :confused:
  • Love
Reactions: D60
Trailer hitch balls are a good example of how things should be. A few sizes to accomodate some different needs, but nothing crazy.
What are the different sizes of trailer hitch balls? The different sizes of trailer hitch balls are 1-7/8-inch, 2-inch, 2-5/16-inch and 3-inch. 1-7/8-inch hitch balls are for light-duty trailers, 2-inch are for medium trailers, 2-5/16-inch are for heavy trailers and 3-inch are for gooseneck trailers.
Living with 4-5 wiper blade choices would be good.
Actually another pet peeve of mine. There is ZERO reason for 1-7/8" when 2" is so close. I will and do immediately cut 1-7/8" couplers off anything that comes with it.
5 lug trailers are another one: you might get 4.5", 4.75", 5" and some run 5.5". Makes no sense.
But I understand your point!
While we're ranting, it seems rear wipers have become a market unto themselves. There's no reason they can't be hook, also.
I just did rear wipers on a '15 Forester and '19 Rogue and the attachments are nothing like any front wipers.
It's just a rubber blade that sweeps across glass, people!!
The rears usually aren't too bad, they are typically a roll-lock connector and most are very similar.
  • Wow
Reactions: D60
There was another thread just like this and I'm still tempted to just get old donor arms and weld/section them on to these stupid new styles.
Even our '08 GMT900 uses GM's stupid squeeze connector.
I hope the aftermarket steps up and starts offering arms with the more-universal hook arms. Wipers are a huge money grab anyway.
Quoting myself and putting my $ where my mouth is. Our newly acquired '15 Tundra uses the pinch tab connectors. I say no. Just no.
I lopped the hook ends off an '05 Exploder from White Trash Land (amusement park with rides coming soon!) behind my shop. Did some quick measurements to keep the pivot in the same spot, and made some bright blue light with the bright blue light machine.
This is what I removed from the stock arms
In addition to bright blue light I made guh-guh-good fu-fu-fumes. I'm totally ok and the stutter is transitory
In the paint booth
Installed, and wipers clocked up for greater defrost benefit
They work well with the washer fluid. I'll post up if the experiment fails in real-world use....like maybe they lift at speed or something.
