After an unexpected failure (without any particular incident taking place) of my Koni struts sway bar link bracket, I wonder what the proper length of my adjustable end links should be.
The aftermarket sway bar I use is adjustable too and is rated at 72% stiffer than the OE bar for its soft setting and 94% stiffer than the OE for its stiffer mounting position, but at what endlinks length and as a result at what ankle with the bar's arms these rates are valid?
During installation the OE endlinks proved incompatible with the aftermarket sway bar (without altering the original car height). It was impossible to connect them to the bar in order to select the stiffer setting and for the softer setting there was no adequate clearance from the front lower control arm in order for the struts to be able to get fully extended.
To cut a long story short, adjustable endlinks where used in place of the OE ones. They were fitted with the car lifted, but they were adjusted at a length that made the angle of the endlinks perpendicular with the bar's arms when the car was on the ground (and at the same time the arms are parallel to the ground surface).
The OE bar's arms (with the OE endlinks) were not parallel with the ground, but were pointing towards it and of course the endlinks were not perpendicular with the bar's arms (see the following schematic).
And now my 2 questions:
- Should I adjust the endlinks length in order for them to be perpendicular to the bar's arms or does that increase the bar's stiffness considerably over its intended rate? If not, obviously I will adjust them to a longer length and I will keep a tighter clearance from the lower control arms.
- Is it crucial for the adjustment to take place with the vehicle on the ground? The opinion I got from an alignment shop is that it does not make any real difference if the car is in the air, because both struts will get equally compressed when the vehicle gets back on the ground and as a result no preload will be added to the bar. According to the shop what makes a crucial difference for the rate of the bar is the length of the endlinks. So does adjusting them on the ground make any real difference?
