For more major parts like Alternator or Starter etc.. you think it is a better bet that you receive the brand and spec you see in the description if you choose wholesaler closeout vs it being labeled as both wholesaler closeout / private label ?? The latter would most likely be under a different brand.. correct?
I know this has come up many times but not on the specifics about which is more likely the more accurate part pertaining to the description.
