Originally Posted By: ZeeOSix
Roller bearings don't operate on hydrodynamic lubrication. The oil pressure is there just so the roller bearings get a good flow of oil supply.
Really I thought a plain bearing spindle was the same thing as a spindle running in preloaded ball or roller bearing races. Machines often use drip or bath lube or grease for anti friction bearing, pressure isn't needed at all. Having clean oil is important to roller bearings though so a filter, not the bearings, would need some kind of flow to clean the oil, even if small. My old mower filters the oil and drops it back to the pan for the splash lube to use it. Never knew it worked that way but it makes sense.
