Have no clue. That's why I asked. Thanks for the response though.Doesn't the bottle usually say Distributed By or something?
I would guess Peak, but who know?
It says distributed by Walmart Inc.Doesn't the bottle usually say Distributed By or something?
Best information says the newish ST Asian is made by Kost USA, a Recochem company. That said, Information on the inhibitor pack is very limited. They also make STP AF.
Yep, we've (you and me) discussed this before. I know the old Recochem Asian formerly sold at PepBoys and shown in link was/is a true Asian Phoat, no 2eha. That was confirmed years ago when PB sold it and it was available in full strength.Most of the ones at my local WM have gone Recochem as well. Prestone used to be the main supplier for my area.
https://www.recochem.com/wp-content...D-Antifreeze-Coolant_USA_ENGLISH_Brochure.pdf
Try to always buy concentrate in order to go to a 60/40 water mix. This lowers the freezing point and increases the boiling point.Yep, we've (you and me) discussed this before. I know the old Recochem Asian formerly sold at PepBoys and shown in link was/is a true Asian Phoat, no 2eha. That was confirmed years ago when PB sold it and it was available in full strength.
Even though Kost is owned by Recochem, there's not much information available on the inhibitors used. 'IF it's the same as the Recochem Asian, no 2eha, I'd be ok with. Price is right. If it's similar to the Prestone 'Asian" AF inhibitor pack, I'd pass.
Noting the comment about Peak (OET) Asian Blue at WM for $10/gal, if one can find that, excellent price.
Yes, if available concentrate always preferable. However, when it comes to topic Asian Phoat AFs (including OEM) the most common and readily available form is 50/50 premix. For vast majority US, 50/50 premix provides all the freezing/boiling point protection needed.Try to always buy concentrate........
how do you know it's "Prestone version"?If they switched to Recochem, that is great! Reochem is good stuff
The OP's bottle is the Prestone version you don't want.
While I agree concentrate is generally a better choice, I disagree that 60% coolant/40% water is desired.Try to always buy concentrate in order to go to a 60/40 water mix. This lowers the freezing point and increases the boiling point.
The distilled water gallon is around $1.29 a gallon post brandon bidenomice. Still comes Out cheaper to buy concentrate. It may save your engine with the extra 10 degrees boil point 260F vs 250F)
It lowers the freezing point, true, but 50/50 is -34F which is more than sufficient for 98+% of the US population.
And water is better for heat transfer, so any benefit on boiling point is negated by worse heat transfer in hot conditions.
If you're coolant is getting over 240-250F you have some other issue or are driving in a manner that requires some other special attention.
Generally you should run the lowest possible coolant for the freezing point you would see with some safety margin.
In the US south that means you should/can do 60% water/40% coolant (-13F freeze point) easily.
