Originally Posted By: KCJeep
Originally Posted By: dlundblad
Ecore filters get a lot of hate, but I have yet to identify the difference between one of these and a cartridge filter. Both have the inner cages.
I don't see them as the same at all. Ecores have poor ADBV's in my experience, a highly suspect combo bypass, and unlike cartridge filters have a nasty tendency to blow holes in the media and through the cage....into the engine...
Didn't you read on this board that it's only a competitor of the Champ/(Fram) that have suspect combo valves. I figured since it was posted here by 'impartial/unbiased authorities' it must be true. Not. I'll abstain from naming the competitor since that claim has never been proven/documented/published it's nothing more than spurious hearsay.
It does remind me of the 'Wix XP/Napa Platinum' using combo valves claim posted here, but now proven completely bogus. That claim was provided by a secret, but if one follows this board an easy to discern source.
Quote:
None of those issues plague cartridge filters that I have seen....
Agreed. The cartridge filters I've used including Wix/Napa Gold and Hyun/Kia Mahle made oem and others posted here generally have tight uniform pleating and no combo valves for bypass to think about. To be fair I will say that the ecores posted lately seem to have tighter uniform pleating similar to cartridges.
As for the Champ nitrile combo valve design, it's worth noting imo, that GM has eschewed it's use in favor of a separate poppet dome bypass in their ACDelco ecores. And older GM have block bypass so no combo valve needed, just ecores with nitrile adbv. So it would appear GM also has no confidence in Champ/(Fram) combo valve design for their newer vehicles with no block bypass.
As for the the topic, STP filters are the lowest tier filters made by Champ. As mentioned many are ecores some using nitrile combo valves. Some applications are downsized consolidated to smallest size. They are the same inside as Wally TLE, Firestone Lube and also the 'Fram' Defense oil filter line.
